Rimac - Electric Super Car 1088hp https://electroavtosam.com.ua/forums/viewtopic.php?f=158&t=371 |
Сторінка 1 із 1 |
Автор: | Вадим [ 20 вер 2014, 00:36 ] |
Заголовок повідомлення: | Rimac - Electric Super Car 1088hp |
Электрический автомобиль Rimac из Хорватии http://www.rimac-automobili.com/press-p11 [youtube]https://www.youtube.com/watch?v=1qodSfhk360&list=PLmHKoUaImSrNZONpkepLxhgn62AzlJbv2[/youtube] Specifications: Performance Power output: 1088 hp Torque: 1600 Nm from 0 to 6500 rpm Acceleration: 0-100 km/h (0-62 mph) 2,8 seconds Range: up to 600 km (realistic range -- 500 km) Braking distance: 31.5m (100-0 km/h) Lateral g-force: 1.4 g Efficiency: 140-550 Wh/km 40 kW on-board charging 100 kW fast DC-charging Weight-to-power ratio: 1.79 kg/hp Weight distribution: 42% front, 58% rear Dimensions Total length: 4548 mm Total width: 1997 mm Total height: 1198 mm Ground clearance: Rear: 115 mm, Front: 105 mm Wheelbase: 2750 mm. Dry weight: 1950 kg Battery-Pack Lithium-Iron-Phosphate (LiFePO4) chemistry Configuration: 1400 cells - 200 series, 7 parallel Voltage: 650V nominal Capacity: 91 kWh Cooling: Freon (gas) with high-voltage heat pumps Milled aluminum and sheet aluminum housing Rimac Automobili Active Battery and Thermal Management Systems Several layers of redundant safety and protection systems Chassis Carbon fibre monocoque with integrated battery-pack Carbon fibre sub-frames (front and rear) Carbon fibre crash structure Front and rear suspension: Double wishbones, fully adjustable, pushrod operated. Electronically adjustable ride height. Fully machined aluminum uprights and wishbones Propulsion System Rear: Rimac Automobili D-PM-OC-600 -- high speed dual permanent magnet oil cooled motors, 600 kW peak, 10.000 RPM, up to 97% efficiency Front: Rimac Automobili D-PM-OC-400 - high speed dual permanent magnet oil cooled motors, 400 kW peak, 10.000 RPM, up to 97% efficiency Dry sump lubrication Milled aluminum housings Reduction gearbox ratio: 3,5 Steering Rack and pinion electrically power assisted steering. Brakes Front brakes: Ventilated ceramic discs Ø 390 mm, 36 mm wide. 6-piston calipers, power-assisted. Rear brakes: Ventilated ceramic discs Ø 380 mm, 34 mm wide. 4-piston calipers, power-assisted. Up to 800 kW of regen-braking (adjustable) Safety Systems Front and side air-bags ABS Torque Vectoring with stability function Safety disconnect systems in case of crash Multiple ECU architecture for monitoring of safety-relevant electronic systems Body Full carbon-fibre body. перевод: Плей лист, суперкаров на батарейках: https://www.youtube.com/playlist?list=P ... n62AzlJbv2 |
Автор: | stoyan [ 20 вер 2014, 06:11 ] |
Заголовок повідомлення: | Re: Rimac - Electric Super Car 1088hp |
... на большое фото достаточно отдельной ссылки, примерно вот так: Вадим писав(ла):
Автор: | Михалыч [ 20 вер 2014, 07:17 ] |
Дорогие Коллеги ! Это правильное замечание, но только наполовину ! Рекламных изданий шедевров мирового Автопрома - СОТНИ. Добрая половина этих шедевров УЖЕ ЭЛЕКТРИЧЕСКИЕ. ! Если некоторые Коллеги, сотую часть тех щедевров перенесут, из глянцевых журналов, сюда, то : ВЫТЕСНЕННЫМ ОТСЮДА , НАМ, ЭНТУЗИАСТАМ -САМОДЕЛЬЩИКАМ ,ЧТО, НОВЫЙ ФОРУМ СОЗДАВАТЬ ПРИДЁТСЯ ? ? ? ...Отсюда и убедительная просьба ко всем : НЕ ЗАБЫВАЙТЕ , ЭТО ФОРУМ САМОДЕЛЬЩИКОВ ЭЛЕКТРОТРАНСПОРТНЫХ СРЕДСТВ. ....Особо, для Вадима: - у Вас уже было одно предупреждение ? |
Автор: | Avtoirich [ 24 вер 2014, 00:12 ] |
Михалыч, буду спорить - хочу потянуть мазу за тех, кто вносит что-то новое в нашу повседневную жизнь, а именно - достижения не только "самделишнего" хар-ра, а и из того же мирового автопрома - а иначе на кого же нам ориентироваться, читай равняться. Что? вариться исключительно "в собственном соку", так не прогрессивно это. Да и недалече из Клуба популяризующего весь электроавтотранспорт, в узкую секту превратится. Ведь Ситрамонщиков-Саксо-"фонистов" мы за своих почитаем и на мероприятия приглашаем и всегда рады им и инфе о них ?!?! А они-то больше серийщики, хотя и самодеятельное конструирование тоже присутствует - а куда же без опыта бывалых?. И вообще, надо быть готовым, что со временем серийщиков станет больше, чем нас здесь самодельщиков и мы должны быть рады здесь их приутствием и даже им помочь. ВЕДЬ МЫ ЖЕ САМИ ЭТО ПОПУЛЯРИЗИРУЕМ!!! т.е к этому идем. Считаю тему - очень даже полезной нужной и даже необходимой. |
Автор: | Вячеслав М [ 24 вер 2014, 08:17 ] |
Электромобиль не роскошь , а способ существования в сегодняшних реалиях . Те , у которых есть соответствующие средства - приобретают серийные электромобили , у которых нет средств - занимаются самоделками или переделками . Создание супер электрокаров демонстрирует технический уровень и технологические возможности . Использование асинхронных двигателей в качестве тяговых , еще двадцать лет назад , считалось фантастикой , а сейчас - это основное направление развития . Я бы сейчас с удовольствием пересел бы на электро NISSAN минивэн , но Электро Славута - это как первый ребенок , как способ и средство познания и создания нового мира свободы . Для некоторых это есть основная цель . |
Сторінка 1 із 1 | Часовий пояс: UTC + 2 години |
