| Новозеландська вантажівка - ZEV 9000 https://electroavtosam.com.ua/forums/viewtopic.php?f=69&t=1064 |
Сторінка 1 із 1 |
| Автор: | paskalex [ 05 лют 2016, 15:37 ] |
| Заголовок повідомлення: | Новозеландська вантажівка - ZEV 9000 |
![]() Опис - https://www.eecabusiness.govt.nz/resources-and-tools/case-studies/new-zealand-made-electric-rubbish-truck-saving-ratepayer-dollars-and-the-environment/ Технічні характеристики - https://www.eecabusiness.govt.nz/assets/Resources-Business/Kapiti-Coast-Rubbish-Truck-FINAL.pdf Цитата: Maximum laden weight (GVW) - 9000kg
Motors - 2 x TM4 liquid cooled three phase radial flux permanent magnet motors Combined Motor power 74 kW sustained, 160 kW peak Combined Motor torque 130 Nm sustained, 340 Nm peak Transmission - ZEV EPU4 with integrated Power Take Off (PTO) Battery capacity - 104 kWh, comprising 108 x 300 Ah cells On-board battery charger - 8 kW single phase Power steering - ZEV electric over hydraulic power steering Headlights – Hella LED Compactor - 5m³ electronically controlled hydraulically operated rear paddle wheel compactor Control electronics including battery management - ZEV EVNet with Wabco ABS |
| Сторінка 1 із 1 | Часовий пояс: UTC + 2 години |
