Поточний час: 30 жовт 2026, 03:50
 Заголовок повідомлення: Новозеландська вантажівка - ZEV 9000
#17728Повідомлення 05 лют 2016, 15:37
Опис - https://www.eecabusiness.govt.nz/resources-and-tools/case-studies/new-zealand-made-electric-rubbish-truck-saving-ratepayer-dollars-and-the-environment/
Технічні характеристики - https://www.eecabusiness.govt.nz/assets/Resources-Business/Kapiti-Coast-Rubbish-Truck-FINAL.pdf
Maximum laden weight (GVW) - 9000kg
Motors - 2 x TM4 liquid cooled three phase radial flux permanent magnet motors
Combined Motor power 74 kW sustained, 160 kW peak
Combined Motor torque 130 Nm sustained, 340 Nm peak
Transmission - ZEV EPU4 with integrated Power Take Off (PTO)
Battery capacity - 104 kWh, comprising 108 x 300 Ah cells
On-board battery charger - 8 kW single phase
Power steering - ZEV electric over hydraulic power steering
Headlights – Hella LED
Compactor - 5m³ electronically controlled hydraulically operated rear paddle wheel compactor
Control electronics including battery management - ZEV EVNet with Wabco ABS
