Поточний час: 04 лист 2025, 06:32
 Заголовок повідомлення: Kangoo Electri'cite - Poland -> Toruń
#129560Повідомлення 28 жовт 2022, 16:14
Дякував (ла) 1 Подякували 5
Мій електротранспорт: Renault Kangoo Electri'cite
Hello all,
at the begining, please forgive me I wrote in English, or I try at least ;)
I found here a lot of good informations about Kangoo I and other electric cars.
Some time ago a friend of mine offered me a Kangoo without batteries. I was told it is fully functional, but batteries where taken as energy storage.
As you can imagine true is far from what I was told.
I connected 12x12V 105Ah AGM batteries for test and carefully check all conections, but car do not drives.
After checking mechanical stuff like gearbox, gear selector, parking mode, etc I decided to open CEVA box.
Results you can see at attached photo.
And here is the main reason of my "comming out" ;)
I need your help to detrmine correct parts.
Thank you in advance ;)
IMG20221027172437.jpg [ 295.24 КБ | Переглядів: 8002 ]
IMG20221027172611.jpg [ 322.34 КБ | Переглядів: 8002 ]
IMG20221028103232.jpg [ 615.8 КБ | Переглядів: 8002 ]
IMG20221028103516.jpg [ 345.7 КБ | Переглядів: 8002 ]
IMG20221011160439.jpg [ 718.04 КБ | Переглядів: 8002 ]
IMG20221011155345.jpg [ 230.54 КБ | Переглядів: 8002 ]
Востаннє редагувалось montergarage 29 жовт 2022, 13:30, редаговано 1 раз.
 Заголовок повідомлення: Re: Kangoo Electri'cite - Poland -> Toruń
#129563Повідомлення 28 жовт 2022, 19:12
Дякував (ла) 22 Подякували 61
Hello! It`s ok to write in english)
I`m not spetialist in e-cars, but did be lead-acid batteries in car in stok? I thought there should be li-ion battery with BMS
#129568Повідомлення 28 жовт 2022, 20:20
Orignally where SAFT Ni-Cd batteries. I bought car without batteries. Only with empty boxes. For testing purposes I put 12 batteries into trunk.
If car will drive on this testing set I will think about Lifepo4 cells and external bms.
For now I'm the BMS ;) I've made display with each battery voltage.
IMG20221021103627.jpg [ 357.63 КБ | Переглядів: 7974 ]
#129581Повідомлення 29 жовт 2022, 11:11
Дякував (ла) 127 Подякували 17
Niech żyje Polska!
We know about symmetrical BMS, about BMS with a balancer, about smart BMS... Now we know about "I'm the BMS" {!_!} . By the way, what is the block of voltmeters made of?
About Kangoo, Stalker and DeLike forum members have experience - they will come and tell you something, or write to them privately.
#129709Повідомлення 03 лист 2022, 09:59
Voltmeters are 0.28 Inch DC from AliExpress. I've only correct their readings according to the same power supply.
I've ordered DSS2X61-01A Schottky diode. I hope is the correct one. Now I need to find other burned parts ;)
#129845Повідомлення 09 лист 2022, 21:47
Доброго дня! Пишіть польською мовою. Нам так буде простіше читати.
У вас згорів вихід DC-DC. Гарна новина: без нього електромобіль може їхати. Погана новини: я стільки палених доріжок в саджем-блоці ще не бачив.
Схоже було коротке замикання десь в електромобілі. Пошукайте сліди замикання +12В в машині. Зачистити плату рідиною для чистки двигунів внутрішнього згоряння (хоч тут від них користь :XD: ). Потім вимийте спиртом. Ретельно просушить і перевірте омметром, щоб залишки хімії не замикали доріжки плати. Відновити доріжки на платі.
Якщо причина замикання усунута, то електромобіль повинен поїхати.
#130350Повідомлення 29 лист 2022, 14:10
No to sprbujemy po polsku.
Masz racje, bylo duze zwarcie na 12V. Mechanik przypadkiem podlaczyl zewnetrzna ladowarke 12V. Niestety zamienil plus i minus. Od tego czasu CLIP pokazuej, ze komputer pracuje, ale brakuje mu jakichs informacji do pelnego rozruchu. Nie ma sygnalu (pikniecia) z zegarow przy rozruchu (wczesniej byl).
Niestety, przy sprawdzaniu znow byl dym z CEVE i okazalo sie, ze spalone zostaly MOSFET ixfk73n30. Udalo mi sie znalezc 4 nowe i znajomy elektryk zajmie sie wymiana i sprawdzeniem plyt... ja stracilem serce do tego :( Mam nadzieje, ze uda sie naprawic, bo Kangoo to na prawde fajne auto.
#130506Повідомлення 11 груд 2022, 10:25
Звідки взнали маркування MOSFET ixfk73n30? Корпус транзистора був цілий або маєте електричну схему?
#130845Повідомлення 04 січ 2023, 16:44
Znalazłem zdjęcia w interenecie, na których było widać oznaczenia. Mam też schematy i listę materiałową części, gdzie jest napisane TMOS N SMD264 73A 300V.
Niestety, uszkodzenia płyty z obwodami są tak duże, że nie wiem czy uda się naprawić. Są spalone ścieżki między elementami. W niektórych miejscach ścieżkio odeszły od płyty z obowodami, w niektórych oczka/punkty lutownicze odpadły.
Mam nadzieję, że płyta ma tylko dwie fukcjonalne warstwy, dolną i górną i będę mógł zrobić obejścia jeśli będzie taka potrzeba.
Na tą chwilę najchętniej bym kupić sprawną, czystą CEVA, a tą oddam komuś na części...
#130894Повідомлення 07 січ 2023, 10:20
Поділіться будь-ласка схемою та переліком деталей. І напишіть свій номер Viber мені в особисті повідомлення - я додам вас до групи українського чату Electro-Kangoo 2000х. В ній інколи продаються запчастини.
#130953Повідомлення 09 січ 2023, 14:36
Muszę sprawdzić te materiały które mam, bo są pobierane z różnych miejsc i się powtarzają. Jak je uporządkuje to załącze.
Na teraz trwa weryfikacja płytek. Nie jest dobrze, sporo uszkodzeń małych elementów w układzie ładowania. Na szczęście większość jest dostępna.
actia_p202831.jpeg [ 252.6 КБ | Переглядів: 6901 ]
